Subject: creating templates
deepa
10 Jul 2008 8:46 AM
hi,
how to create template in dotnetnuke.
i want to use snapsis menu  which should dispaly the menus in horizontal manner.how to achieve this?whether we have to use template or anyother option is there.
let me know asap.
thanks,
deepa
10 Jul 2008 2:20 PM
Templates are for the content of your DNN site, rather than the skin design of the site:
DotNetNuke Portal Templates and the Site Wizard
For the snapsis menu, have a look at the code in the skin examples that come with the snapsis menu and any documentation from the snapsis website.
Forums > DotNetNuke® > DotNetNuke® Questions > creating templates
