Subject: purpose of 3 User controls which are created while creating a new module
kishoreD
09 Jul 2008 9:23 AM
I am working with dotnetnuke 04.05.05 version. I am creating a new module using the template "Dotnetnuke Dynamic Module". Now it creates some files including 3 user controls (View----.ascx, Edit---.ascx and Settings.ascx.
Can anybody explain the use of each user control? Please consider this as Urgent.
Kishore
09 Jul 2008 9:38 AM
Get a copy of the DotNetNuke Module Developers Guide from the DotNetNuke.com site.
Forums > DotNetNuke® > DotNetNuke® Questions > purpose of 3 User controls which are created while creating a new module
