Subject: How to Assign childs and parant menu colors in sanpsis
rao_babu24
09 Jul 2008 8:56 AM
pls reply if any know.
I am the new guy this DotnetNuke .
 Thanks advance
rao
09 Jul 2008 9:14 AM
Have you looked at the samples that come with the Snapsis menu? With that and the documentation, I was able to figure this out, but it's been months since I've really looked at it.
rao_babu24
09 Jul 2008 11:54 PM
Thanks for reply
But i can't undersatand u r reply. u have any sample pls help.
Many thanks
advance
10 Jul 2008 7:40 AM
The Snapsis menu includes some samples, and there is a modest user manual. You can look at samples there. As I recall, there are styles included for both parent and child items.
Forums > DotNetNuke® > DotNetNuke® Questions > How to Assign childs and parant menu colors in sanpsis
