Subject: Is DotNetNuke Supports Oracle Database?
kishoreD
09 Jul 2008 8:26 AM
Hi Folks,
I am currently working wiht Dotnetnuke 04.05.05 version with SQL Server database.
I would like to know that can we use Oracle database instead of SQL Server database. If so what is the procedure to use Oracle Data Provider?
Do we need to purchage Oracle Data Provider inorder to work with Oracle database? or it is coming with dotnetnuke as of the sql server data provider.
please guide me...!
Kishore.
09 Jul 2008 9:06 AM
There is a commercial data provider. Look for it at Snowcovered.
Before purchasing, though, you might want to ask about support for third-party or other commercial module support.
Forums > DotNetNuke® > DotNetNuke® Questions > Is DotNetNuke Supports Oracle Database?
