Subject: Adding Flash to Skin as Relative URL
cfwebmasters
08 Jul 2008 7:46 AM
Have a flash movie in a skin but it needs to be a relative URL associated with the skin (so can move skin around without having to worry about which Portal # it is in). Right now have it being referenced by /Portal/6/rotate/header.swf but need it to be like rotate/header.swf from the main skin folder I am using.
I have the graphics done like this with the code but cant get the flash to work (coding is below). This is a slideshow pro flash movie which also uses and .xml file within the rotate folder. Any help is greatly appreciated.
(Current flash movie URL and needs to be changed to rotate/header where /Portal/6/rotate/header.swf is)
    [script removed]
08 Jul 2008 7:15 PM
Try referring to this as /rotate/header.swf. It should work
Forums > DotNetNuke® > DotNetNuke® Questions > Adding Flash to Skin as Relative URL
