Subject: how to use sifr in dotnetnuke
rao_babu24
07 Jul 2008 4:10 AM
hi
what is the meaning of sifr. what is the roal of sifr in dotnetnuke .
 pls help me I am new for this technology.
regards
rao
07 Jul 2008 8:22 AM
Incorporating sIFR (Scalable Inman Flash Replacement) with DotNetNuke skins
rao_babu24
07 Jul 2008 8:45 AM
hi
thanks for reply
but how to develope application using sifr in dotnetnuke
do have that sample video.
regards
rao
10 Jul 2008 1:29 PM
The sample video is video 1 of the tutorial, to fully understand you will need to watch all 7 videos.
From the tutorial page:
sIFR works by swapping your text element with a Flash file. A piece of Javascript is used which scans the page for any text within a tag or class name. The text is then replaced with a flash file. The technique only uses one flash file for each font type. The text is placed within this flash font file and is then displayed on the page. If you only use one font for all of your headers, you will just use one flash file which will be duplicated across your page.
Forums > DotNetNuke® > DotNetNuke® Questions > how to use sifr in dotnetnuke
