Subject: XML settings for Feedback Module
saintX
04 Jul 2008 10:14 AM
I don't want the help (blue question marks) to be dispalayed besides the fields of the feed back module.
I assume it is been set in the xml document. If yes, what are the xml settings for this tocken?
10 Jul 2008 1:06 PM
hello,
This is the method I have found:
Add the feedback module to a page
Each module on a page has a unique ID, to identify the ID used web developers toolbar, in the menu select information / display ID & class details
This will display the IDs for all of the elements within your DotNetNuke page, identify the ID for the feedback module
In my example the ID is: #dnn_ctr377_ModuleContent
From here we can write some CSS to identify any images within this ID and set them to not display, ie:
#dnn_ctr377_ModuleContent img {
display: none;
Add this to your skin.css file
This will remove the help question marks.
You can find more information for working with the web developers toolbar in this tutorial: Troubleshooting DotNetNuke Skins
Hope this helps,
Forums > DotNetNuke® > DotNetNuke® Questions > XML settings for Feedback Module
