Subject: how to develop skins in dotnetnuke
rao_babu24
04 Jul 2008 5:56 AM
how to develope skins for dotnetnuke
thanks advance
04 Jul 2008 6:14 AM
If you go to the main tutorials page and scroll to the bottom you will see a big list of skinning tutorials.
If you are new to skinning I would recommend you start at  Issue no 5 and 6 and then work through the tutorials in issue number order, this will teach you the basics and then progress onto CSS skinning,
Forums > DotNetNuke® > DotNetNuke® Questions > how to develop skins in dotnetnuke
Glad you sorted it, thanks,
