Subject: Registration Completion Event
billkidwell
02 Jul 2008 4:13 PM
Is there a tutorial or something similar that explains how to send an auto responder to someone who registers? I have looked at the Completion Event area on the dynamic registration page, but since I am absolutely a non-techie' I am not comfortable with my understanding of any of the things that can be set there and I have questions about how to send an auto-reponder to someone who jsut registers, versus somewho who chooses one of our security role-based "paid" subscriber options.
02 Jul 2008 7:39 PM
Have you read the user manual?
You might want to ask for help from DataSprings?
Forums > DotNetNuke® > DotNetNuke® Questions > Registration Completion Event
