Subject: Under Construction page
crook_sam
01 Jul 2008 8:12 AM
Hi there,
                  I am currently buliding a site in DNN but there are a few people who have the address of the site that i don not want to see it whilst it is under construction. Is there a way that i can display an under construction sort of page to those people whilst I can continue to work on the site online? thanks very much.
Sam.
01 Jul 2008 8:26 AM
You could temporarily create an "under construction" page and mark it as the Home page, and restrict all of the other pages to "Administrative Access" using the page settings. Only that page would be available, but you would see everything when logged in as an admin.
crook_sam
01 Jul 2008 8:36 AM
Thats great and will serve perfectly, why didnt i think of that! haha. Have you any idea how to remove the search function from just this page i cant seem to get rid of it.
Thanks a lot for such a quick reply it is really appreciated!!
Sam.
01 Jul 2008 9:35 AM
create a copy of your skin and remove the [SEARCH] token from the skin
Then just set the new skin to display on the home 'under construction' page
Forums > DotNetNuke® > DotNetNuke® Questions > Under Construction page
