Subject: multiple subdomin
vdelisi
01 Jul 2008 4:13 AM
I'm designing a site that has many subdomain each for a target city like this:
city1.mysite.com
city2.mysite.com
cityn.mysite.com
Now I want to develop and maintain only one site .... how can I do?
Maybe create different portals, each for a city, it is not the right choice because is like to build different portal.
Vincenzo
02 Jul 2008 3:01 AM
perhaps it would be worth searching on snowcovered for any modules that allow the sharing of registered users between portals, this way you can set it up as separate portals, but still have the users able to access all portals.
I have not attempted this, so let us know your findings, thanks,
02 Jul 2008 7:41 PM
I believe that DataSprings' Dynamic Login module handles the single login issue.
vdelisi
16 Jul 2008 8:38 AM
coming back on this topic, I need a site that works www.kijiji.com
where there are products visible only for the local site like
http://newyork.kijiji.com/
Do you know how is it possible to do?
Vincenzo
17 Jul 2008 8:39 AM
You'd have to have a separate store with separate products for each site.
vdelisi
17 Jul 2008 9:45 AM
Sure, I've my db with the column "city", the main problem is it possible to setup dotnetnuke ...child portal ? single portal with url rewriting? ...I don't know
Enzo
RE: Database error by derpir
