Subject: How to change BEHost username
kaustav_kar
30 Jun 2008 5:33 AM
how can I change the username BEHost to any other username.
30 Jun 2008 10:59 PM
Username appears in the aspnet_Users table and the Users table. Presumably you just need to change those two entries.
I'd try this on a test setup before doing it to a live site.
01 Jul 2008 5:54 AM
or, if you do not wish to mess with the DotNetNuke tables, you could simply create a new host user account with a different username, make sure it has full host access and then delete the old host account. -   Again I would fully test this before deleteing the original host user account incase some modules are linking to that account
kaustav_kar
14 Jul 2008 3:02 AM
Thanks for that. Can u please tell me in which table the passwords are saved?
14 Jul 2008 8:49 AM
The passwords are stored in asp_membership. If you've chosen to use encrypted or hashed passwords, they might not be accessible, though.
Forums > DotNetNuke® > DotNetNuke® Questions > How to change BEHost username
ok great, glad to help,
