Subject: Issue in Link Module
UmaRam
30 Jun 2008 4:47 AM
I have created a base portal, in which I have added many pages, skin, menus and link controls. Then I have exported this portal as template without any content. But all the links were missing in that template.
So I have created another template with all contents. I am using Onyak portal signup module for creating child portal. In signup settings, I have selected the new template with content as the template and I have created a child portal.
Now I have few issues in link module .
In child portal, all the links are pointing to base portal's tabID. So it is fetching the base template data. For ex, In the base template I have selected the blue skin. In the child portal I am using orange skin. Once I click the link "Edit Profile" it is redirecting to base template with blue skin for that page. I feel that link contents are uploaded from the base template and are not updated with respect to new child portal (new tabid). How can I overcome this problem?
Uma
Nuke Master I
Nuke Master I
30 Jun 2008 11:01 PM
Once you have created the new portal, you can use the Admin menu Site Settings to adjust things to your liking.
If I understand correctly, you exported a template with settings from a site that used the blue skin. Using that as the template for the new site should also use the blue skin. But, once the site has been created, you can change it.
Forums > DotNetNuke® > DotNetNuke® Questions > Issue in Link Module
RE: style search CSS or XML by mmcinulty
Hi Leei was able to replicate the mouse over affect by using the css, the problem is that i still ha...
Still no luck with this feed. I can get both of these links to render if pasted in Internet Explore...
thanks for posting info,
03.04.00 Thanks Bryan
