Subject: Permanent Redirect 301
vdelisi
27 Jun 2008 3:50 AM
I would like to have the following rules, only to avoid duplicate content on google, of redirection on my site:
 - www.mysite.com : redirect on the dnn folder eg. C.\......\dnn
 - mysite.com: have a permanent redirect 301 on http://www.mysite.com
I'm using WebHost4Life as provider
On PortalAlias Table I've www.mysite.com
Vincenzo
Forums > DotNetNuke® > DotNetNuke® Questions > Permanent Redirect 301
