Subject: Change Colors of Account Module text
Carmos
25 Jun 2008 2:55 PM
I have a skin which places a graphic with a black background behind the Account Login module.
In CSS I say "Color: white" to make the Text white and show up on the black background.
The only control showing white text is the Login button.
The User Name help link, Password help link, Register link and Forgot Password link are all Blue.
What command do I need to add to make them White?
Thanx in advance.
01 Jul 2008 4:41 AM
It depends what CSS class you have assigned to them.
If you created your skin with a html file in the skin.xml file you will have specified a class for each of the tokens, so you need to view which classes you have specified for the tokens and then set the CSS styling for those classes.
If you have created your skin using skin.ascx files, look at the code and you will see CssClass is specified for each token, so from here you can view the CSS classes for styling the tokens and add the CSS into your skin.CSS file.
You may find this tutorial useful which details how to identify IDs and classes within your DotNetNuke installation using the web developers toolbar:
Forums > DotNetNuke® > DotNetNuke® Questions > Change Colors of Account Module text
Backup Live Website without control panel? by ollep
We are hosting with Re-Invent.com, a DNN host that doesn’t allow Control Panel access. We are ther...
Hi Slowly sorting it out. www.goldcoastwebwiz.com/dotnetnuke/q1 The logo position is OK. B...
Glad you sorted it, thanks,
