Subject: Lee Sykes Tutorials - Premade Files
buc2
24 Jun 2008 6:21 PM
I'm new to DotNetNuke and trying to walk through the tutorials.  I am working with the "Skinning Tutorials" and am in video #2.  It references a "premade" set of files that includes, "index.doctype.xml", "skin.xml", and "Housemenu readme".
Where do these premade files come from??  Where can I get these files???  Help!
24 Jun 2008 6:46 PM
Those files should be available for download on the page from which you've downloaded the tutorial. "Video #2" doesn't identifiy the tutorial. If you can be more specific, I'll know where to look.
buc2
24 Jun 2008 6:59 PM
Hi Joe, and thank you for your reply.
I'm working with the "How to create a DotNetNuke CSS skin from an XHTML template (part 1) - 6 Videos".  I'm working in video #2 and the reference is made to a set of "paremade files".
I have searched for the file - "Housemenu Readme" file but, don't know where else to search for it.
I'm beginning to think the changes are made as a part of the video and the actual file is not necessary to have in hand.
I have felt I needed the file but, after much review I think the reference to the file was just for purposes of demonstration.
25 Jun 2008 5:43 AM
The HouseMenu ReadMe file will be in the zip file of the HouseMenu skin object that you downloaded from House of Nuke, thanks,
Forums > DotNetNuke® > DotNetNuke® Questions > Lee Sykes Tutorials - Premade Files
