Subject: Duplicate Entries in "Display Threads" Dropdownlist
kishoreD
24 Jun 2008 4:40 AM
I am working with DotNetNuke Forum 04.04.03 version. Functionality wise everything is working file. But some of the Forum features like "Ratings" and "Display Thread" drop down lists having some issues.
"Display threads from" : This drop down list is having some duplicate entries
"Rankings : This drop down list is having some invisible rankings. If i selet these getting some junk message beside the thread.
Please find the attached gif file for more information and guide me how to resolves this.
Kishore
Forums > DotNetNuke® > DotNetNuke® Questions > Duplicate Entries in "Display Threads" Dropdownlist
