Subject: Retreive Time Zone
UmaRam
19 Jun 2008 6:12 AM
User is selecting the time zone in manage profile page. I have tried to get tje time zone selected using userinfo class. But it is returning some value like -480 etc for the time zone.
How can i retreive the selected the time zone and compare it with the user systems' time zone?
Uma
19 Jun 2008 9:56 PM
If you look at the namespace Class DotNetNuke.Entities.Users.UserTime you'll find some items relative to time zones.
carlitossalcedo
01 Oct 2008 6:09 PM
can somebody tell me how can i update the new selected timezone of a user
01 Oct 2008 6:34 PM
If you are the administrator, you can edit the User's profile to do this.
Forums > DotNetNuke® > DotNetNuke® Questions > Retreive Time Zone
