Subject: survey module
UmaRam
19 Jun 2008 5:19 AM
hi,
I am using survey module in my app. As a host user I am able to add questions for the polling.
I have to provide a link in the same page "New Question". If the admin user clicks this link, it should redirect to "add question" page ?
How to acheive this?
22 Jun 2008 8:29 AM
You can find the URL that you need if you navigate to the Add a Question page. You can then copy the URL and use it in your site.
