nlewis
 Nuke Newbie Posts:4
| 18 Jun 2008 12:40 PM |
| I recently installed DotNetNuke locally. The install went fine. After being prompted to change my password at the initial log-in I have not been able to log into the site. Each time I enter the username and password I am simply redirected back to the home page, but I'm never logged in. Is there any way to solve this problem? I am using 4.8.3. Any suggestions would be appreciated. |
jncraig DNN Creative Staff
 Nuke Master II Posts:2371
| 18 Jun 2008 12:48 PM |
| Have you tried asking the site to send you your password, or initiate the change password sequence? |
nlewis
 Nuke Newbie Posts:4
| 18 Jun 2008 2:41 PM |
| It's local so no. I know the password and I know that it works. I just that I can never successfully login. I am always sent back to the home page. |
leesykes DNN Creative Staff
 Nuke Master III Posts:3375
nlewis
 Nuke Newbie Posts:4
| 19 Jun 2008 9:04 AM |
| I can register new users. But it still won't let me actually login. Weird huh? Also, I know that it actually recognizes the password because when I mistype it, the appropriate screen appears telling me so. |
doordoughnut DNN Creative Magazine Subscriber
 Nuke Newbie Posts:1
| 19 Jun 2008 3:52 PM |
| I belive that I hade the same problem recently. Once you have entered user name and password, are you pressing enter or using mouse to click on submit. Every time I pressed enter I ended up a my home page. My experience happend a week ago after upgrading to 4.8.4. Now on 4.8.3 and is okay. |
ariane_mondragon
 Nuke Newbie Posts:5
| 20 Jun 2008 6:01 AM |
I have almost the same problem as yours, but the only difference is, I can't even see the textboxes for username and password. When I click the LOG-IN link, nothing happens... But I was able to edit the site after my installation.
Thanks in advance for helping me solve my problem...
ariane_mondragon
 Nuke Newbie Posts:5
| 23 Jun 2008 5:02 AM |
I am using the default skin...
nlewis
 Nuke Newbie Posts:4
| 24 Jun 2008 7:46 AM |
| no custom skin for me either. |
| 24 Jun 2008 8:12 AM |
Does you skin show the Login and Register links? If so, do these get filled in with a username after you try to login but are redirected to the home page? Can you give the link to your site? If you don't want to publish is, you can send it to "jncraig at yahoo.com." |
ariane_mondragon
 Nuke Newbie Posts:5
| 25 Jun 2008 10:50 PM |
Yes, I can see the Register and Login Links but I'm just being redirected to the home page, everytime I click the Login Link(Register Link works...)... During the installation, I didn't change anything in web.config file because once I edit something, error comes out. Do you think, that has something to do with the odd problem I am experiencing now?...
I installed DotNetNuke 4.8.3 on my local computer. I'm not yet publishing it. I've been trying to install it for how many times...but same error occurs...
By the way Sir, thanks for helping me to figure out the problem...
ariane_mondragon
 Nuke Newbie Posts:5
| 26 Jun 2008 6:52 AM |
I figured out the problem...Using the auto and custom installation, this problem occurs but when I tried using the Typical installation, I can now go to the log-in page...:') Everything works fine now...thanks for the help... |
Verce
 Nuke Newbie Posts:8
| 11 Jul 2008 4:37 AM |
I have the same problem and I am using the Typical installation. The installation was successful. I'm just being redirected to the home page every time I press "Login" after I enter my password. help.. |
Verce
 Nuke Newbie Posts:8
| 11 Jul 2008 8:56 AM |
yes.. And I reinstall it once because I thought maybe I made a mistake trought the installation process, but I get the same problem again. And I don't see the Control Panel on the top. |
Verce
 Nuke Newbie Posts:8
| 16 Jul 2008 10:00 AM |
Hey... I try on Mozila and it worked [Smile] I didn't change anything. Thanks anyway |
