Subject: Mode Bar appears for regular logged in users
18 Jun 2008 10:27 AM
Just noticed this on a site ...
If a regular user logs in, the "Mode Bar" appears at the top with choices for "View" and "Edit" but no "Design" and no Control Panel drop down.  The user can select between the two radio buttons, but nothing really happens.
I created a test page with a stock DotNetNuke skin, and get the same behavior on that page.  So, I'm assuming that this is not a skin issue.  But, where does it come from and how to I fix it?
18 Jun 2008 12:47 PM
Well ... Doh! (I had marked a module editable by regular users ...)
18 Jun 2008 3:49 PM
lol - yep the simple ones always catch us out! - Glad you sorted it!
Forums > DotNetNuke® > DotNetNuke® Questions > Mode Bar appears for regular logged in users
