Subject: Help on a scenario
jwinters
18 Jun 2008 9:42 AM
I am trying to set up a this scenario:
When a client logs into my site, I want to present them with specific data (their own). I don't want others to be able to see that information.
How would I go about this?
Thanks in advance.
Jon
18 Jun 2008 12:54 PM
You can create pages that only that user will be able to access.
In a more general scenario, if the data is structured the same for each user, you can contruct a module, or perhaps configure the module to display the data based on the logged in user's userid or username.
I'd need more details to be more specific than that.
jwinters
18 Jun 2008 4:30 PM
That sounds like what I was thinking...
Basically, know the client, specify a role for the client, and then manually create a page for that client only they could see upon login...
That sounds really tedious.
Now the module part might work... basically still need to create a role unless the module could pick up username and password...
Are there any modules that do this?
Jon
19 Jun 2008 8:44 PM
I don't know of a module that alters content based on the username or userid, but I think that you can do something like this with modules like xmod.
Forums > DotNetNuke® > DotNetNuke® Questions > Help on a scenario
