Subject: Link is missing in Template
UmaRam
18 Jun 2008 8:24 AM
I have created few pages with links. I created this site as a template using "Export to Template" option. In that, I have unchecked the checkbox "Include content".
I attempted to create a child portal using this template in order to provide basic features in the child portal. But all the pages are displaying properly, but no link is displayed. (i have used DNN link module)
Any solution to create a template without content, but with links.
Uma
18 Jun 2008 12:55 PM
The links in the Links Module ARE the content of that module. So, you should export the content of that module so that you can import in into the other site.
Forums > DotNetNuke® > DotNetNuke® Questions > Link is missing in Template
