Subject: New to DNN
Fenix247
18 Jun 2008 7:52 AM
Just a quick question to DNN developers - how easy or difficult is it to get upto speed with DNN - If one wants to create a portal?
Fenix247
davidrushton
18 Jun 2008 8:07 AM
Hi Fenix,
Personally I think it's pretty easy to learn the basics, enough to get a portal up and running. Up until recently I had never done anything with DNN, but I soon picked up the basics. The videos on DNN Creative are fantastic, so I would recommend these as a starting point.
18 Jun 2008 8:17 AM
I agree that it's fairly easy. The largest conceptual hurdle faced by some is "Where are the pages stored?"
I also recommend that you get a good book to help you along.
My first book was the "Professional DotNetNuke 4" book by Shaun Walker and friends. That one probably has a lot of material that won't be appreciated by or appropriate for somebody who just wants to build a a web site.
There is a "Dummies" book, and there are several others that focus more on the website building side of things. I haven't read any of them because I've still got my "inappropriate" book.
18 Jun 2008 8:18 AM
Hi Fenix,
Yes you should be able to get up and running quickly with the videos on here, just start at issue 1 and work your way through - each issue builds on the knowledge of previous issues. - Within a couple of hours you should have the basics which you can then expand on depending on what you need to learn at the time. - Of course we are always here to help in the DNN creative forum as well so please feel free to ask any questions,
Lee
