Subject: Issue moving from local to live
vdelisi
18 Jun 2008 2:52 AM
I've developed on a local installation thanks to yours video. Now I'm moving to a live installation but I've the following issues:
 - typing the www address it open the local site
In my site I've two portal alias
 - localhost/mysite
 - www.mysite.com
In the portalalias table the PortalAliasID are
 - 2 for localhost
 - 3 for www
How can I solve it?
Enzo
18 Jun 2008 7:35 AM
Backup first, then
Try deleting the localhost alias in the portalalias table, thanks,
vdelisi
18 Jun 2008 8:17 AM
Already tried but without success...the behaviour is that on the status bar i read "website found ..." on the title flips www.mysite.com with www.mysite.com/?tabid=36 after one minute explorer shows the following error
Internet Explorer cannot display the webpage
Most likely causes:
You are not connected to the Internet.
The website is encountering problems.
There might be a typing error in the address.
What you can try:
Check your Internet connection. Try visiting another website to make sure you are connected.
Retype the address.
Go back to the previous page
vdelisi
18 Jun 2008 9:06 AM
More information if could be useful get with Http Wath to trace the request www.saileasy.com (real name)
+ 0.000  0.261 398 1924 GET 302 Redirect to http://www.saileasy.com/?tabid=36 http://www.saileasy.com/
+ 0.261  0.215 407 1915 GET 302 Redirect to http://www.saileasy.com/ http://www.saileasy.com/?tabid=36
+ 0.477  0.214 398 1924 GET 302 Redirect to http://www.saileasy.com/?tabid=36 http://www.saileasy.com/
+ 0.692  0.213 407 1915 GET 302 Redirect to http://www.saileasy.com/ http://www.saileasy.com/?tabid=36
+ 0.907  0.214 398 1924 GET 302 Redirect to http://www.saileasy.com/?tabid=36 http://www.saileasy.com/
+ 1.121  0.215 407 1915 GET 302 Redirect to http://www.saileasy.com/ http://www.saileasy.com/?tabid=36
+ 1.337  0.215 398 1924 GET 302 Redirect to http://www.saileasy.com/?tabid=36 http://www.saileasy.com/
+ 1.554  0.404 407 1915 GET 302 Redirect to http://www.saileasy.com/ http://www.saileasy.com/?tabid=36
+ 1.959  0.214 398 1924 GET 302 Redirect to http://www.saileasy.com/?tabid=36 http://www.saileasy.com/
+ 2.174  0.214 407 1915 GET 302 Redirect to http://www.saileasy.com/ http://www.saileasy.com/?tabid=36
+ 2.389  1.189 398 1024 GET 302 text/html; charset=utf-8 http://www.saileasy.com/
While if I use
http://www.saileasy.com/ Home /tabid/36/default.aspx
it works
Thanks for your help
Forums > DotNetNuke® > DotNetNuke® Questions > Issue moving from local to live
