Subject: I'm stumped with how to move my content
mtarby
17 Jun 2008 11:48 AM
I have some legacy content that I need to move to a new instance of DNN.  This content is stored in various SQL tables.  I'm trying to figure out how to get this content from point A (the old SQL) to point B (my instance of DNN)
My first thought was to export the content into an XML file, which worked fine, until I realized that we wouldn't be able to edit the XML file in DNN.
Then I was thinking that I could somehow set up a user defined table and populate it with the data I was exporting from my SQL table, but wasn't sure if that could be done.
Any advice would be appreciated.
17 Jun 2008 1:22 PM
That maybe possible, I would suggest you setup a test UDT module and see how it handles the tables and then see if you can adapt your current data into the format to match the UDT tables.
Otherwise, you may be able to import the tables straight into your DNN database and then use the reports module to present the data that you require. - But you wouldn't be able to edit the data.
Other options could be to build a module specially for this, or look at modules such as XMOD or bi4ce List X and see if they can integrate with your data.
Anyone else got any thoughts? Thanks,
Lee
Forums > DotNetNuke® > DotNetNuke® Questions > I'm stumped with how to move my content
