Subject: From where to change the content of opt in e-mail
kaustav_kar
16 Jun 2008 4:50 AM
Hi, from where we can change the contents of the opt-in newsletter mail that goes to the site administrator(not the subscriber) when somebody subscribes to the opt-in newsletters?
16 Jun 2008 4:07 PM
For the emails sent out by your DNN portal, go to:
admin menu / languages / language editor
local resources
in here you will need to look in the folders to identify the specific emails you wish to edit, but all content that DNN sends via email is stored in this languages area.
Forums > DotNetNuke® > DotNetNuke® Questions > From where to change the content of opt in e-mail
