Subject: CSS validation
emboldener
11 Jun 2008 7:49 AM
I am trying to validate CSS for my site as it is required by the client.
If I run the css through the W3C CSS validator before DNN integration, it passes:
http://ifne.emboldendesign.com/buildout/content.html
When I run through the CSS validator after DNN integration, it  gives me this error:
Servlet has thrown exception:javax.servlet.ServletException: Timed out
http://ifne.emboldendesign.com/DefaultPermissions/AboutUs/tabid/152/Default.aspx
I've tried on several other DNN sites that we have developed and get the same error. Any ideas?
thanks,
Suzanne
16 Jun 2008 2:36 PM
The default.css file that comes with DotNetNuke has invalid CSS code in it.
Further info here: Reducing the DotNetNuke CSS file sizes
This is for an older version of DNN, so some of the CSS in the default.css has changed, but the same principles apply and should give you a good starting point for fixing the errors and reducing the size of the file.
emboldener
11 Jul 2008 9:25 AM
Thanks, I fixed the default.css styles. Turns out what was throwing the validator error was  a double quote in an inline style on default.aspx. So, I was able to run it through and it passed!
-sj
