Subject: How to Built a page in dotnet nuke
Tanmaya
05 Jun 2008 4:22 AM
every body.I want to learn dotnetnuke. I am new in this technology.Currently i am working in .Net only.
I want to build a page in dotnetnuke.How can I do this. what should i do so that i can build and run one page in dotnet nuke.
05 Jun 2008 4:57 AM
For a good start check out these free tutorials:
Tanmaya
11 Jun 2008 7:48 AM
Thank you for your well guidance.
As a beginner For testing purpose i created a new website using dotnet nuke.Then pressed ctrl+F5 for running the application, before this i just gave my database access path in web.config file.At run time its showing some "Run Database Installation Scripts" and it keeps on going for a long time duration.i waited for 1 hour for completion of that database script, but it did n't finish.i don't know why that wizard is coming and how much time it takes for completion.Plz Help.........
11 Jun 2008 7:38 PM
I find it MUCH easier to set up and operate a basic website outside of Visual Studio. Use IIS, and point the website at your web directory and then browse to it.
I believe that the issue you describe is related to AJAX ... and possibly AJAX isn't done properly through VS. You might want to make sure that AJAX is installed on your computer.
Tanmaya
17 Jun 2008 4:03 AM
I did n't  get your instruction regading how to setup and  operate a basic website without using visual studio.Can you make it more clear.
Also i need  to upload/deploy my project in server.I built a simple website in dotnet nuke using visual studio editor. Usally in  .net we used to publish the site and upload the published files in server.But here i tried same thing after publish the dotnet nuke website.But nothing is coming up.Please help on this.........i want to put my project in server.
17 Jun 2008 6:24 AM
For info on setting up and installing DNN, have a look here:
Tanmaya
17 Jun 2008 7:47 AM
Thanks again.
I was checking with host login in dotnet nuke website.Under host menu>>module definition, i want to add some new modules as well as new skins for my website.please suggest where can i get these things.Is there any source whcih i can use??????? Thanks
17 Jun 2008 7:57 AM
A lot of people use Snowcovered for purchasing modules and skins.
If you are looking for free, we have some resources listed here: Module Directory Free Modules
We also have several free skins available here
Tanmaya
18 Jun 2008 6:05 AM
Sorry, i checked those free skins link that you have mentioned but i did n't get an option to down load the skins or modules. its showing the text which tells to down load but exactly there is no link to down load  instead its redirecting to new page.... Plz help on this.
Also how can i built my own skins and modules in dotnet nuke.I searched through the site but i did n't get any video clips for this.Plz help on this.I have gone through one clip which tells we can add our own custom built skin or modules.Plz suggest how can i built custom defined skins and modules to apply in my project.Thanks....
18 Jun 2008 7:20 AM
There is a download link for each those skins when you view each of the main skins page.
A quick list of the download pages is here:
Free Pure CSS Skins
18 Jun 2008 7:21 AM
To build skins, look at the tutorials on this page:
http://www.dnncreative.com/Tutorials/tabid/261/Default.aspx
scroll to the bottom and there you will see a long list of skinning tutorials available to subscribers, thanks,
Lee
Forums > DotNetNuke® > DotNetNuke® Questions > How to Built a page in dotnet nuke
