Subject: free CV upload/show module dnn 4.0 or above?
nukedoubt
29 May 2008 1:14 PM
Is there any free CV upload/show module in dnn 4.0 or above?
thank you
30 May 2008 8:22 AM
CV? As in Curriculum Vitae?
You could probably use the Repository or Documents module for this. If you were using the Repository module, try the business card or portfolio templates.
Forums > DotNetNuke® > DotNetNuke® Questions > free CV upload/show module dnn 4.0 or above?
