Subject: Menu Advice
sannaf
25 May 2008 10:57 AM
Hi Lee,
I am trying to replicate a relatively simple menu:
A horizontal menu
showing root level items on one line
and sub menu itmes for the selected root item horizontally underneath
i want the sub menu to be static so they only change when a new itme is selected from the root level
in addition i want to be able to style the active root and sub menu item
i am not overly concerned about showing the admin host menu in this menu,
and i am not to bothered if the menu is css or java based
to give you a feel for what i am trying to achieve i have attached a screen -shot of the menu i am trying to replicate....
Thanks in advance for your help
sannaf
25 May 2008 11:17 AM
sorry i think i have found my answer here>>
http://www.dnncreative.com/Tutorials/SkinningTutorials/HorizontalCSSHouseMenu/tabid/271/Default.aspx
25 May 2008 3:20 PM
Yes, you can certainly do this.
I use the Snapsis Nav Menu to accomplish this at stockcentral.com, but you can also do it with other menus.
