Subject: Login Issue with Firefox on GoDaddy Hosted Site
rearviewmirror
23 May 2008 12:36 PM
This DNN site, version 4.8.0, is hosted on GoDaddy. When a user logs in using Firefox 2.0.0.14, the site redirects to the home page and all is well. When clicking on a menu item to visit a different page, the user is immediately logged out. When clicking on the Login link at the top of the page, the user is automatically logged in and redirected to the home page with no prompt to enter a user name and password. Everything works fine in IE 6, with the exception of logging out; the link must be clicked twice in order to actually be logged out.
I can provide a test user, if necessary. Any help is greatly appreciated!
www.authorityzero.com
Forums > DotNetNuke® > DotNetNuke® Questions > Login Issue with Firefox on GoDaddy Hosted Site
