Subject: Module Permissions Issue
lolorn
23 May 2008 8:44 AM
Some time ago I set a module's permissions so only administrators could see and edit it. When I changed the permissions (as the host) on that module today so that "all users" can view the module, it's still visible only to administrators and still comes up with the red box around it indicating "visible by administrators only"
The page is set to allow "all users" to view the page, but whether I set the permissions so the module inherits the page settings, or manually set the module to allow all users to view it, the module is still visible to administrators only.
I've tried testing this by setting the permissions on other modules on the same page so only administrators had permission to view them, but I can switch these back to all users permissions with no problems.
I know that I'm probably missing something obvious, but would someone mind pointing it out?
23 May 2008 10:55 AM
It's possible that you are seeing a cached version of the page. Try going to Host Settings, clear the cache, and restart the application.
lolorn
28 May 2008 9:21 AM
I did as you said and tried clearing and then restarting the application, and still no luck. Even if I set the module so all users should be able to see and edit it, it's still not visible to anyone other than an administrator. Anything else I should try?
28 May 2008 10:50 PM
No, it should work.
Forums > DotNetNuke® > DotNetNuke® Questions > Module Permissions Issue
