Subject: how do i get my home link to work....
cipher2079
21 May 2008 10:27 PM
how do i get my home link to work again, I am trying to get back into web building and I complete forgot how to fix my home link url to point to the direction that it should go.
i know there is tutorial here somewhere about this but i can't find it
22 May 2008 7:54 AM
Can you ask this again. I don't understand the issue.
cipher2079
22 May 2008 2:29 PM
I am currently trying to build a website, I am using the tutorial on how to build a website
when i changed the soulpart menu to houseofnuke housemenu skin object, my home link stop working properly
for example: it use to point to the url my localhost:xxxx, now it does not.
so my question is if there is any where in my localhost website files to make the appropriate changes, or can it be done some other way.
22 May 2008 11:12 PM
I think that you must have done something wrong with the menu. If you use one of the standard DotNetNuke skins -- and you can change skins in an instant -- does your home page return and work correctly? If so, that narrows the problem to the skin and how you may have configured the menu.
23 May 2008 8:19 AM
Go to the admin menu / site settings / advanced settings / page management / Home Page:
Here you can select the page that will be used as the Home Page
cipher2079
25 May 2008 11:19 AM
Hello Lee,
 I was hoping that I could go into a file and hardcode the change, however mabey the way you explain to do it is better,
I remember doing a tutorial on manipulating tabsdigit)  http://localhost:1046/DotNetNuke%20Website2/SkinDemoPage/Page3NoContent/tabid/56/Default.aspx
I think i can find the answer in one of those tutorials
the link above is actually pointing to my "Page3Ncontent" page hence my Home page points to the wrong url:
  http://localhost/dotnetnuke%20website2
as you can see it does not have the number ( ://localhost:1046/)
thus, pointing to the wrong page. how can I change this url to point to the write place
http://localhost:1046/dotnetnuke%20website2
I tried deleting the home page to then create a new one but I got:
A page defined as Home, Splash, Login or User Page for the portal, or the last visible Page in the portal cannot be deleted.
cipher2079
25 May 2008 11:52 AM
I just finished trying to creating a new home page, after testing the new home page out I notice that it pointed to the currect url however once i made it the defualt home page  it went back to pointing to the wrong url
25 May 2008 3:14 PM
Here is my advice: NEVER, NEVER, ... NEVER change the source code. Get to know the tools that the framework provides and use them. By not changing the code, you'll be able to upgrade easily.
cipher2079
27 May 2008 7:45 AM
all I want is to fix this problem, I NEVER changed the source code, I would like to find were I can change the source code of the actual url not the url form of working but just the actual http:// adress and correct it to point to the right place
27 May 2008 8:25 AM
The Home page should automatically appear in you menu. Make sure that the page is named "Home" and that you clear the Home Page entry in site settings. That is used if your Home page isn't named "Home."
There is no place in the source code to change the url ...
If your home page is not pointing home, there is some other error.
Forums > DotNetNuke® > DotNetNuke® Questions > how do i get my home link to work....
Glad you sorted it, thanks,
