Subject: How can I implement .net forms authentication in DNN?
pvirk
21 May 2008 5:01 PM
I am in the process of migrating an existing asp.net website over to Dot Net Nuke.  This website uses .net forms authentication to secure files in a particular directory, and users must first go through a login page before they are allowed access to these files.  How can I implement this same functionality in DNN?
I can see that the default web.config file in the DNN root directory already has a reference to enable forms authentiation, but I can't figure out how to apply this to any specific portal that I create.  Has anyone here come up against this same issue?
My platform uses the .net 2.0 framework and DNN 4.  Any help would be greatly appreciated.
pvirk
Forums > DotNetNuke® > DotNetNuke® Questions > How can I implement .net forms authentication in DNN?
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
