Subject: Fixing Ugly URL's
digitaldoom
21 May 2008 12:18 PM
I've noticed that the QueryStrings in DNN (with Friendly URLs turned off) show Tabid=XXX.
Is there anyway to force DNN to use QueryStrings that have something to do with the page name?
From a friends site built off some PHP Wiki Tool:
http://docs.centercode.com/default.php?n=NewUserGuide.ProjectUserManagement
n = relevant page information
Is there any way to get DNN to do something like this?
It seems the only other option is to turn on Friendly URL's, but then I get an ugly 'tabid/xx' in the path.
I would really like a that:
(a) Didn't contain references to a folder that doesn't exist
(b) Contained QueryString Values with some Page Level Meaning (see above link)
Is there a way to get those two things with DNN?
I'd install a module to do it, if that would fix it.
Nuke Master I
Nuke Master I
22 May 2008 11:20 PM
DotNetNuke has some "friendly URL" features. You might look there.
digitaldoom
23 May 2008 9:10 AM
Posted By jncraig on 22 May 2008 11:20 PM
From my original post:
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
