Subject: error in SQL Server authentication login password
msr
20 May 2008 3:00 PM
I'm in the process to transfer a dnn site from localhost to live.
I've followed instructions from videos in "transferring localhost to live site" tutorial...
In my local SQL Server 2005 installation => SQL Server Management EXPRESS => when I have to create a new security login name => I select "SQL Server Authentication" and I write and rewrite password (imagine 10 char) + click OK with no error and new login is created ...
BUT: when I click again in the new created login to see it again it allways appears an unknown password with 15 char that I don't know when it comes from ... I've never been able to change this "default 15 char password" ...
Obviously when I update "web.config" file with new connection string I don't know what password to include ... And when I try to start up the dnn site I obtain the following error message:
Exception Details: System.Data.SqlClient.SqlException: Error de inicio de sesión del usuario 'dnn_test2'. =>> is my login database user
Source Error:
Stack Trace:
<PRE>[SqlException (0x80131904): Error de inicio de sesión del usuario 'dnn_test2'.]
   System.Data.ProviderBase.DbConnectionPool.GetConnection(DbConnection owningObject) +435
   System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection) +82
   System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +105
   System.Data.SqlClient.SqlConnection.Open() +111
   Microsoft.ApplicationBlocks.Data.SqlHelperParameterCache.DiscoverSpParameterSet(SqlConnection connection, String spName, Boolean includeReturnValueParameter, Object[] parameterValues) +204
   Microsoft.ApplicationBlocks.Data.SqlHelperParameterCache.GetSpParameterSetInternal(SqlConnection connection, String spName, Boolean includeReturnValueParameter) +303
   Microsoft.ApplicationBlocks.Data.SqlHelperParameterCache.GetSpParameterSet(String connectionString, String spName, Boolean includeReturnValueParameter) +154
   Microsoft.ApplicationBlocks.Data.SqlHelperParameterCache.GetSpParameterSet(String connectionString, String spName) +36
   Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(String connectionString, String spName, Object[] parameterValues) +200
   DotNetNuke.Services.Log.EventLog.DBLoggingProvider.Data.SqlDataProvider.GetLogTypeConfigInfo() +68
   DotNetNuke.Services.Log.EventLog.DBLoggingProvider.DBLoggingProvider.GetLogTypeConfigInfo() +108
   DotNetNuke.Services.Log.EventLog.DBLoggingProvider.DBLoggingProvider.GetLogTypeConfigInfoByKey(String LogTypeKey, String LogTypePortalID) +62
   DotNetNuke.Services.Log.EventLog.DBLoggingProvider.DBLoggingProvider.AddLog(LogInfo objLogInfo) +72
   DotNetNuke.Services.Log.EventLog.LogController.AddLog(LogInfo objLogInfo) +188
</PRE>
20 May 2008 8:48 PM
Are you sure that the password isn't just being shown as a string of asterisks: ***********?
This is a standard security precaution.
You also have to give the new login db ownership privileges.
Forums > DotNetNuke® > DotNetNuke® Questions > error in SQL Server authentication login password
ok great, glad to help,
