Subject: Different background image on each page
dtownsend
20 May 2008 1:30 PM
My graphic designers want to use a different background image on each page of a site (see attachments)
Other than the background image, the page layouts, menus etc are identical across all pages.
It seems like overkill to create a separate skin for each page.  I am thinking there must be a way of using CSS to achieve this.
i.e. all the pages use the same skin and I just have to assign different CSS files to each page.
20 May 2008 8:52 PM
No, I wouldn't do it with skins, but I'd make that part of the page content. Just as you have different content on each page, you will have different images.
23 May 2008 7:53 AM
You could target each unique Text / HTML module with CSS and specify a background image for those elements, for instance:
Each module has a unique ID assigned to it.
For instance, go to: http://www.dnncreative.com/tabid/75/Default.aspx
Using the web developers toolbar go to the Information menu / Display ID & Class Details
From here you can see the main Text / HTML module has a unique ID of #dnn_ctr380
There are various variations of this ID, you will be able to view:
#dnn_ctr380_contentpane .dnnC_content_transparent DNNAlignleft
#dnn_ctr380_ModuleContent
#dnn_ctr380_HtmlModule_lblContent .Normal
We can target the main content area of the Text / HTML module with:
border: 10px solid orange;
For further info on the web Developers Toolbar view:Troubleshooting DotNetNuke Skins
Forums > DotNetNuke® > DotNetNuke® Questions > Different background image on each page
