Subject: DNN, Adobe Flash Streaming Server...
zelky
19 May 2008 5:05 AM
I need to build a site like this:
http://www.donkingtv.com/
It's going to be a simliar site, so I need to implement a way for people to pay via credit card to watch a video, and I then need to run the videos from a server running Adobe Flash Media Streaming Server 3.
Any ideas?
Forums > DotNetNuke® > DotNetNuke® Questions > DNN, Adobe Flash Streaming Server...
ok great, glad to help,
