Subject: Menu item individual styles
owensammut
14 May 2008 9:12 AM
I need to create a menu with different colours for the parent menu items and a drop down with the same colour as the parent. Im on a budget so i would prefer if the menu was free or freeish or is there anyway i can hard code the menu?
thanks for your help and please keep up the good work
17 May 2008 8:01 PM
I would refer you to Lee's excellent "Skinning Toolkit" for help.
It might be best to change the colors of each menu item by using background images. I haven't ever tried something like this but it seems that it should work.
As for menus, besides the one that comes with DotNetNuke there is also House of Nuke (I believe a new version has been released recently) and I can recommend John Mitchell's Snapsis Nav Menu because I do use it. There are other menus, too.
Forums > DotNetNuke® > DotNetNuke® Questions > Menu item individual styles
