Subject: Not Really A DNN Question
mgordon
09 May 2008 11:16 AM
But I am hoping you've addressed this in one of your tutorials.
I need to have a subdomain/child portal(?) to my www.pwcparks.org website.  I need it to be:  report.pwcparks.org, or something like that.  Have you done a tutorial that shows how to create  or mess with Host Headers?  If you have, which tutorial would I use?  I do have the #17 issue, but it shows how you've already created Host Headers?
Thanks....btw, Joe...Mitchel Sellers is proving to be a godsend in help.  Thank you for referring me to him.  He is worth every penny,  just like DNN Creative is worth every penny.
Lee, I hope everything is going well with you.  Cheers!
Nuke Master I
Nuke Master I
09 May 2008 11:24 AM
Mark,
All that you need to do is create the second site, and it can be either a child site or a parent site.
You then have your DNS set up so that report.pwcparks.org will point to the same IP address as your other site. Finally, add a portal alias for report.pwcparks.org in your new site.
That should do it ...
I'm glad my other recommendation is working out, too!
mgordon
09 May 2008 11:53 AM
Hi Joe,
That's where I'm being thrown for a loop...setting up the DNS.  I'm with the county and do  not have access to their DNS server.  Am I going to need to have them do this?  If so, what exactly should I be telling them to do?  I only have access to my IIS Server.
Mark
Nuke Master I
Nuke Master I
09 May 2008 11:59 AM
Yes. If they manage your DNS, they are the ones with whom you will have to deal. Tell them that you want the new domain to point to the same IP address as the existing domain. On your end, all that you have to do is add the portal alias entry for your new site. You can do that now, leaving the existing alias. Then, you'll know that they've done their part when the new domain works.
mgordon
09 May 2008 12:08 PM
OK, but where do the Host Headers in IIS come in?
I've contacted the county and they are going to add the pointers to the urls I want.  So that's going smooth.
mgordon
09 May 2008 12:19 PM
Nuke Master I
Nuke Master I
09 May 2008 12:33 PM
No, I think that will break things. The requests should be forwarded to the DotNetNuke installation, and DotNetNuke then uses the Portal Alias entries to send the responses. This is ALL handled within the single DotNetNuke installation.
mgordon
09 May 2008 12:35 PM
Forums > DotNetNuke® > DotNetNuke® Questions > Not Really A DNN Question
RE: Sync with module to module (announcement) by ryutopia
I think I have some sense.... When I add one external RSS feed site in News Feed Module for testing...
FCKEditor + Behavior by mgordon
Hi All,I'm having a frustrating time with the FCKEditor.  When I go to edit the text, it defaults to...
RE: Zip files getting corrupted when downloaded by jncraig
Hmmm ... let us know what you find.
RE: login module by jncraig
What I do is use the standard dnnUser and dnnLogin skin objects wrapped in some conditional coding s...
RE: Guestbook by jncraig
Recommendations, anyone?
RE: [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS. by jncraig
Something is wrong either with your IIS installation, or the way you created the IIS website.  Take ...
RE: store account login issues by jncraig
The key to fixing this is in your skin. Without knowing your skin design, it's hard to tell you how...
RE: [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS. by sattysir
I got the same error "This error can be caused by a virtual directory not being configured as an app...
store account login issues by mparrett
hello, my site is jewellers-online.net and as you can see my account module is in the left pane a...
RE: Zip files getting corrupted when downloaded by omorgan
Thanks Joe, I wondered if it was something like that but wasn't sure where to look. I'll go ahead...
Guestbook by jesp17
Hi,Is there also a good guestbook module for DNN?
RE: SMTP Setting error by sondlerd
I got it to work. I am actually using Windows 2003 Server. I had to set the address of the Host em...
login module by Bobbyjosephg
Hi   The login module becomes blank when the user successfully logs in.Is there any configuration se...
RE: Sync with module to module (announcement) by leesykes
I'm not sure what is happening there. When you go the the paret portal page it should automatically ...
I did as you mentioned. Could you tell me if this is normal? When I click the icon of RSS on one mo...
RE: UDT Module advanced search capability by jncraig
The answer I read from Sebastian Leupold is that you can't do this with the current version of the m...
You need to go into web.config and fix the setting for the maximum file size. It's default value is...
RE: Sync with module to module (announcement) by jncraig
Add an RSS module to the parent site. Configure it to collect from every child site. In answer t...
RE: control panel keeping rolling up by jncraig
I haven't heard of that before. I'd check to make sure that AJAX and Java are installed correctly. ...
  Joe, Thank you for your reply. Could you tell me how to set the parent site up to subscribe to ...
