Subject: Forum - My Setting ERROR
ajoshi
09 May 2008 8:21 AM
For one of my forums, when I go to My Settings I get the following error.  Any suggestions?
Error: User Settings is currently unavailable.
DotNetNuke.Services.Exceptions.ModuleLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetNuke.Modules.Forum.UserSettings.SelectMultiTreeItems(DnnTree objTree, Int32 ForumID) at DotNetNuke.Modules.Forum.UserSettings.Page_Load(Object sender, EventArgs e) --- End of inner exception stack trace ---
Nuke Master I
Nuke Master I
09 May 2008 9:34 AM
Is the forums module working othewise?
ajoshi
09 May 2008 9:39 AM
Well, what I am trying to do is configure email notification for the forum. So if there any new posts, all users get an email. If I try to do it under host account, I get the error above but I have an another Administrator account, I can do it through that. I am not sure if this is a big issue but I shouldn't have to create additional administrar account. Host account should be able to do it.
Anyways, goign back to the email notfication problem. A user gets an automatic email when he is registered to the forum but the posting email notification doesn't work. Any suggestions?
Thanks in advance.
Nuke Master I
Nuke Master I
09 May 2008 10:16 AM
Are you using the stock DotNetNuke Forum module?
If so, it's possible that there is a bug. I note that I don't get notifications from the forums at the DotNetNuke website. You might want to ask over there if there are problems.
Forums > DotNetNuke® > DotNetNuke® Questions > Forum - My Setting ERROR
Main Menu Bar by saliml
Is it possible to remove the Main menu Bar which is at the top of the page of Dotnetnuke sites which...
Different background image on each page by dtownsend
Hi,My graphic designers want to use a different background image on each page of a site (see attachm...
RE: Sync with module to module (announcement) by ryutopia
I think I have some sense.... When I add one external RSS feed site in News Feed Module for testing...
FCKEditor + Behavior by mgordon
Hi All,I'm having a frustrating time with the FCKEditor.  When I go to edit the text, it defaults to...
RE: Zip files getting corrupted when downloaded by jncraig
Hmmm ... let us know what you find.
RE: login module by jncraig
What I do is use the standard dnnUser and dnnLogin skin objects wrapped in some conditional coding s...
RE: Guestbook by jncraig
Recommendations, anyone?
RE: [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS. by jncraig
Something is wrong either with your IIS installation, or the way you created the IIS website.  Take ...
RE: store account login issues by jncraig
The key to fixing this is in your skin. Without knowing your skin design, it's hard to tell you how...
RE: [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS. by sattysir
I got the same error "This error can be caused by a virtual directory not being configured as an app...
store account login issues by mparrett
hello, my site is jewellers-online.net and as you can see my account module is in the left pane a...
RE: Zip files getting corrupted when downloaded by omorgan
Thanks Joe, I wondered if it was something like that but wasn't sure where to look. I'll go ahead...
Guestbook by jesp17
Hi,Is there also a good guestbook module for DNN?
RE: SMTP Setting error by sondlerd
I got it to work. I am actually using Windows 2003 Server. I had to set the address of the Host em...
login module by Bobbyjosephg
Hi   The login module becomes blank when the user successfully logs in.Is there any configuration se...
RE: Sync with module to module (announcement) by leesykes
I'm not sure what is happening there. When you go the the paret portal page it should automatically ...
I did as you mentioned. Could you tell me if this is normal? When I click the icon of RSS on one mo...
RE: UDT Module advanced search capability by jncraig
The answer I read from Sebastian Leupold is that you can't do this with the current version of the m...
You need to go into web.config and fix the setting for the maximum file size. It's default value is...
RE: Sync with module to module (announcement) by jncraig
Add an RSS module to the parent site. Configure it to collect from every child site. In answer t...
