| RE: Assign a css id to a module. by corourke |
| Thanks for the suggestion jncraig. I've made the suggestion: http://support.dotnetnuke.com/issue/Vie... |
| RE: Host menu gone? by vijaymoharle |
| Hi,
Host is menu is available for Superuser.
When you install DNN it will ask for New Admin a... |
| dotnetnuke compiler error by wdarnellg |
| I am trying to transfer my dotnetnuke files from localhost to my live account. I have followed the s... |
| RE: Assign a css id to a module. by jncraig |
| I agree. Why don't you make that suggestion at dotnetnuke.com. |
| RE: Document management Modules by jncraig |
| I'm not aware of a module with all of these features. If you find one, please let us know. |
| RE: how do i get my home link to work.... by jncraig |
| Can you ask this again. I don't understand the issue. |
| RE: Default Events Module XHTML by emedia |
| I can't seem to locate the Visual Studio Solution file for the Events Module, I know most modules no... |
| how do i get my home link to work.... by cipher2079 |
| how do i get my home link to work again, I am trying to get back into web building and I complete fo... |
| Hey guys,I'm new to DNN and have been trying to make a specific install of DNN XHTML compliant. Gen... |
| How can I implement .net forms authentication in DNN? by pvirk |
| Hello,I am in the process of migrating an existing asp.net website over to Dot Net Nuke. This websi... |
| Fixing Ugly URL's by digitaldoom |
| I've noticed that the QueryStrings in DNN (with Friendly URLs turned off) show Tabid=XXX.Is there an... |
| RE: Host menu gone? by digitaldoom |
| I had this problem also... My whole Host account is gone. When I login with Admin and I view a... |
| That's what I've been doing so far however that adds extra divs which isn't the most semantic way to... |
| Editing Blog Module to say News instead of Blog by omorgan |
| Hello,I'm trying to find where I can edit the blog module from saying Blog to make it say News. My b... |
| RE: Document management Modules by jfitzgerald |
| Ideally the following
Check in\ out facility – Giving audit trail of who has ‘checked out’ the do... |
| What functionality would such a module have? |
| RE: control panel keeping rolling up by jncraig |
| Well ... I haven't seen this problem in IE, so your job might not be over ... |
| Hi Guys,I'm trying to find out if dnn has an advanced document management module?Can anyone help??Ma... |
| RE: control panel keeping rolling up by rizwan7705 |
| thanks for trying to help me out but problem was with windows internet explorer 7.when i tryed firfo... |
| RE: Main Menu Bar by jncraig |
| If you learn a little bit about skinning, you can do this easily by removing those controls from the... |
