Subject: content shown to registered users
flupkede
08 May 2008 3:04 PM
I was wondering if it is possible without writing custom controls to have a link on the page redirecting to a "you should register or login first" page instead of the registered users content.
I'm using Xmod and I want the "Add" functionality to always appear (now it becomes invisible) so a user can click on it and get the above message.
Now I just have a static link that redirects to a new record page in xmod, but this generates of course an error into xmod when the user is not loggedin
I need to do something like you guys do with the video links shown or hidden depending wether someone has logged on.
Thx,
Filip.
Nuke Master I
Nuke Master I
08 May 2008 7:16 PM
I'm not quite sure what you are trying to do, so could you please restate the problem.
If youre users are going to pages where they don't have viewing privileges, they should be redirected to the login page. You can add text modules there to explain what they need to do.
Forums > DotNetNuke® > DotNetNuke® Questions > content shown to registered users
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
