Subject: error in installation
saliml
08 May 2008 2:54 PM
I am re-installing the source of dotnetnuke after I deleted it because it was generating an asp.net error. During the instalation the tests that are on the second page and the third page of installation ( permissions and database) were successfull. When I reach the page which installs the database scripts and after the installation added sever tables to the database it is giving this error:
Installing Database - Version 4.4.0...FAILURE 400 - Thread was being aborted.
I shall appreciate any help to solve this problem. Many thanks.
Nuke Master I
Nuke Master I
08 May 2008 7:15 PM
I'm not quite sure what the problem is, but you shouldn't be installing the source package for a live site. You should use the install package.
Forums > DotNetNuke® > DotNetNuke® Questions > error in installation
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
