Subject: Module Load Warning
srikaracharya
08 May 2008 1:20 AM
Please help why am i getting this error?
When i try to installing new module or while accessing the other pages i am getting this warning message . Why? Please help
"Module Load Warning
One or more of the modules on this page did not load. This may be temporary. Please refresh the page (click F5 in most browsers). If the problem persists, please let the Site Administrator know."
Nuke Master I
Nuke Master I
08 May 2008 7:37 AM
If you login as host, you'll see a more detailed error. Also, look in the event viewer for more details.
srikaracharya
09 May 2008 1:16 AM
Dear jncraig,
 There was no log in event viewer for this warning. I could not understand  why this problem arise.
Nuke Master I
Nuke Master I
09 May 2008 9:35 AM
Have you tried restart the application, restarting IIS, or restarting the server? Do this error persist through all of that?
And, which module is not loading?
Forums > DotNetNuke® > DotNetNuke® Questions > Module Load Warning
How can I implement .net forms authentication in DNN? by pvirk
Hello,I am in the process of migrating an existing asp.net website over to Dot Net Nuke.  This websi...
Fixing Ugly URL's by digitaldoom
I've noticed that the QueryStrings in DNN (with Friendly URLs turned off) show Tabid=XXX.Is there an...
RE: Host menu gone? by digitaldoom
I had this problem also... My whole Host account is gone. When I login with Admin and I view a...
RE: Assign a css id to a module. by corourke
That's what I've been doing so far however that adds extra divs which isn't the most semantic way to...
Editing Blog Module to say News instead of Blog by omorgan
Hello,I'm trying to find where I can edit the blog module from saying Blog to make it say News. My b...
RE: Document management Modules by jfitzgerald
Ideally the following Check in\ out facility – Giving audit trail of who has ‘checked out’ the do...
RE: Document management Modules by jncraig
What functionality would such a module have?
RE: control panel keeping rolling up by jncraig
Well ... I haven't seen this problem in IE, so your job might not be over ...
Hi Guys,I'm trying to find out if dnn has an advanced document management module?Can anyone help??Ma...
RE: control panel keeping rolling up by rizwan7705
thanks for trying to help me out but problem was with windows internet explorer 7.when i tryed firfo...
RE: Main Menu Bar by jncraig
If you learn a little bit about skinning, you can do this easily by removing those controls from the...
RE: Main Menu Bar by saliml
I need to remove both the bar together with the seach control
RE: Assign a css id to a module. by jncraig
Use the Header and Footer of the advanced module settings to wrap a div tag around the module, and s...
RE: FCKEditor + Behavior by jncraig
Ummm ... no. But I hope somebody else has some ideas.
RE: Different background image on each page by jncraig
No, I wouldn't do it with skins, but I'd make that part of the page content. Just as you have diffe...
This is part of the skin and certainly can be removed. I'd recommend that you begin by viewing some...
RE: error in SQL Server authentication login password by jncraig
Are you sure that the password isn't just being shown as a string of asterisks: ***********? This...
RE: SolPartMenu and organization by jncraig
I don't believe that there is a place to specify that pages are in alphabetical order. But, you can...
RE: Container Spacing by jncraig
Is this done with a Text/HTML module? Have you looked at the HTML source to see what is there? Y...
Hmmm ... this is an odd one. Can you perhaps make a second DotNetNuke installation and see if it ha...
