Subject: Module Load Warning
srikaracharya
08 May 2008 1:20 AM
Please help why am i getting this error?
When i try to installing new module or while accessing the other pages i am getting this warning message . Why? Please help
"Module Load Warning
One or more of the modules on this page did not load. This may be temporary. Please refresh the page (click F5 in most browsers). If the problem persists, please let the Site Administrator know."
08 May 2008 7:37 AM
If you login as host, you'll see a more detailed error. Also, look in the event viewer for more details.
srikaracharya
09 May 2008 1:16 AM
Dear jncraig,
 There was no log in event viewer for this warning. I could not understand  why this problem arise.
09 May 2008 9:35 AM
Have you tried restart the application, restarting IIS, or restarting the server? Do this error persist through all of that?
And, which module is not loading?
davidbian
27 May 2008 3:01 AM
hi, Joe,
i got the same error too.
Module Load Warning
i restarted the IIS and app poo but came to nothing.
i chekced the event log and found this:
<ArrayOfAnyType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
       <anyType xsi:type="LogDetailInfo">
              <name>ModuleIdname>
              <value>-1value>
       anyType>
              <name>ModuleDefIdname>
              <value>-1value>
       anyType>
              <name>FriendlyNamename>
              <value />
       anyType>
              <name>ModuleControlSourcename>
       anyType>
              <name>AssemblyVersionname>
              <value>04.03.04value>
       anyType>
              <name>PortalIDname>
              <value>0value>
       anyType>
              <name>PortalNamename>
              <value>BlitzBooks®value>
       anyType>
              <name>UserIDname>
              <value>-1value>
       anyType>
              <name>UserNamename>
              <value />
       anyType>
              <name>ActiveTabIDname>
              <value>36value>
       anyType>
              <name>ActiveTabNamename>
              <value>Homevalue>
       anyType>
              <name>RawURLname>
              <value>/Default.aspxvalue>
       anyType>
              <name>AbsoluteURLname>
       anyType>
              <name>AbsoluteURLReferrername>
              <value />
       anyType>
              <name>UserAgentname>
       anyType>
              <name>DefaultDataProvidername>
              <value>DotNetNuke.Data.SqlDataProvider, DotNetNuke.SqlDataProvidervalue>
       anyType>
              <name>ExceptionGUIDname>
              <value>d2ec77fc-46bb-45f4-89cf-6fa8d52b04d4value>
       anyType>
              <name>InnerExceptionname>
              <value>Unhandled error loading module.value>
       anyType>
              <name>FileNamename>
       anyType>
              <name>FileLineNumbername>
              <value>0value>
       anyType>
              <name>FileColumnNumbername>
              <value>0value>
       anyType>
              <name>Methodname>
              <value>System.Web.Compilation.BuildManager.PostProcessFoundBuildResultvalue>
       anyType>
              <name>StackTracename>
       anyType>
              <name>Messagename>
              <value>DotNetNuke.Services.Exceptions.ModuleLoadException: Unhandled error loading module. ---> System.Web.HttpCompileException: D:\inetpub\vhosts\blitzbooks.com.au\httpdocs\Portals\_default\Containers\DNN-Blue\Image Header - Color Background.ascx(19): error BC30560: 'admin_containers_actionbutton_ascx' is ambiguous in the namespace 'ASP'.     at System.Web.Compilation.BuildManager.PostProcessFoundBuildResult(BuildResult result, Boolean keyFromVPP, VirtualPath virtualPath)     at System.Web.Compilation.BuildManager.GetBuildResultFromCacheInternal(String cacheKey, Boolean keyFromVPP, VirtualPath virtualPath, Int64 hashCode)     at System.Web.Compilation.BuildManager.GetVPathBuildResultFromCacheInternal(VirtualPath virtualPath)     at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)     at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)     at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath)     at System.Web.UI.TemplateControl.LoadControl(String virtualPath)     at DotNetNuke.UI.Skins.Skin.LoadContainer(String ContainerPath, Control objPane)     --- End of inner exception stack trace ---value>
       anyType>
              <name>Sourcename>
       anyType>
ArrayOfAnyType>
Any ideas?
thanks a lot.
27 May 2008 8:30 AM
There is also a DotNetNuke event log, but it's likely to show the same thing.
Is this a new installation? If so, you might want to try reinstalling. There error refers to the standard DNN-Blue Skin, so something is really wrong
Forums > DotNetNuke® > DotNetNuke® Questions > Module Load Warning
