Subject: Updates fail without IIS restart
dp6ai
07 May 2008 3:47 AM
Hi all,
Often when im updating a site (i.e adding modules) the updates fail (the screen just hangs) until i restart IIS at which point the updates work fine..
Has anyone had this issue in the past?
DNN ver: 04.08.00.
Thanks in advance.
dp
09 May 2008 9:02 AM
I haven't come across that problem, thanks,
Forums > DotNetNuke® > DotNetNuke® Questions > Updates fail without IIS restart
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
