Subject: how do I allow access to downloads after checkout
seniah08
03 May 2008 4:25 AM
Hi Lee and all around DNNCreative
I am wondering how you configure the core store module to change permissions to allow downloads of certain items once they have been paid for.
if this is not possible could someone pls suggest a module that i could get to do this.
Thnx
Sam
10 May 2008 3:05 AM
No this is not possible with the store module, you can do this though:
But, I would recommend looking for a 3rd party module, the one we use on DNN Creative is from www.ventrian.com - the subscription tools module.
Forums > DotNetNuke® > DotNetNuke® Questions > how do I allow access to downloads after checkout
