Subject: moduleid returns -1
nukedoubt
02 May 2008 9:00 PM
why moduleid is returning -1
In my viewpage.ascx, when i check moduleid, it is returning -1.  But the module id is perfectly getting in settings.ascx
why this error and how can it overcome
thankzzzzzzzzz
Forums > DotNetNuke® > DotNetNuke® Questions > moduleid returns -1
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
